One more thing…. I found something in the documentation that seemed to answer a question / need I had….
”The cover window also supports drag and drop in both directions”.
Is this in the PC version only? Because I tried re-ordering images this way in the Mac version but haven’t been able to so far.
This part of the documentation refers to adding cover art to files by dragging an image, e.g., from Finder, and to saving cover art by dragging the cover from the Tag Panel to a target outside Mp3tag.
Reordering embedded images is on my internal wish list, but it's currently not possible except by adding the covers in the desired sequence.
I've moved your post to a separate topic, as it covers a different subject from the one you originally posted in.
Reordering embedded images is now possible with Mp3tag for Mac v1.12 via the Manage Covers feature, available from the Covers menu or ⇧⌘C, allowing you to add, remove, replace, adjust, and reorder embedded cover art for one or multiple files.
