Re-size Cover Art
I can drag cover art into prescribed box and tell it to re-size to 320x320 (biggest size my car will display), I can save to all relevant mp3’s, but when I check the sizes have not changed.
I am using version 3.31a and this bug is the first time this has not re-sized correctly.
It's resizing fine here in my initial tests. Can you give step-by-step instructions on how to reproduce the issue you're describing?
What I did:
  1. Select Files without cover art
  2. Drag cover art to cover window
  3. Right click on cover window and choose Adjust cover, where I set to 320 and press OK
  4. Save changes via Ctrl+S
