hi,
i have a large collection in a folder, it take a good while for mp3tag to open it. i like to know if there is a way to speed up this process. we are talking like over 14000 files and growing.
Thank You
hi,
Thank You
Enable the library (File->Options->Library) and if you use Windows Defender as an antivirus program, define an exception for mp3tag.exe.
Thank You that corrected it. another question in the tag panel is there a way to resize the boxes. the year box is stretched out and i like it the same size as the track box.
Thank You
You should open a new thread for a new question, but yes, there is. Fields in the Tag Panel can be sized Large, Medium, Small, Smaller and Multiline.
Sory about that problem is corrected Thanks again.
