For some time now, Mp3tag has included a feature that renames associated CDG and LRC files whenever the filename of the corresponding audio file is changed.
If you add these two extensions to the list of file suffixes Mp3tag is configured to display, the files will also appear when loading folders.
Renaming works as intended; however, the file list is not updated for the CDG and LRC files.
While triggering a refresh might be feasible when only a few files are loaded, it is hardly practical when your entire music library has been loaded.
