I use the following replace with regex to shorten multiple entries in the ARTIST field to only the first artist.
When I have multiple artists they are always saparated by " / " so i use the following regex
Regex ARTIST ./. --> ""
This works fine almost all the time. However it causes me a problem if there is a "." in the artist name.
ie. For some reason this will make "R. Kelly" --> "R"
How can I make this regex only pick up the forward slash (/) and not pick up a "." ?
Thanks very much if you can help
