Regex: Remove 2nd set of parenthesis in TITLE
Evening Gents. This has been 'answered' on numerous posts but unfortunately I have yet to find any of the example regex postings to work (typically deletes everything but the actual song title). I have a few songs with TITLE like
Something (Ft Mama Jane) (Prod. None)
I want to remove the second set of parenthesis completely so it just says
Can anyone clue me into the expression to use?
Try:
$regexp('Something (Ft Mama Jane) (Prod. None)','(.*\)) \(.*\)',$1)
It stripped everything...Made it just say Something
Would it be easier to just ask how to regex and remove anything that is (Prod.
So what did you enter and have as data?
It worked over here:
You are correct; it works on that particular song. i should have probably led with that; that is my fault
What i meant to say was that it doesnt work on other songs unless i implicitly add the song title and the Ft quote for the new song. Is there a way to do it so it dynamically does that to all songs I have that are like that?
I assumed that you are able to replace the fixed string with the field variable.
So, does
$regexp(%title%,'(.*\)) \(.*\)',$1)
work?
... and it would really help if you showed real examples, preferably with a screenshot.
I realized what I was doing wrong. I was doing it under actions (which doesnt work there) instead of under convert using tag-tag.
That works! I appreciate it!
It does work with an action of the type "Format value".
If you want to use "Replace with regular expression", you have to split up the 3 parts of $regexp() into the 3 parameters in the action dialogue.
But again: all these different assumptions could have been avoided with screenshots.
needle: "(\)) \(.*"
replacement: "$1"
