Regex Required: SPACE • DOT
#1
When tagging multiple-disc albums, I usually let Mp3tag fetch the album name (or a portion thereof) from the %_directory% field, using the Format Value Action. The album name then may look something like this:
"The Ultimate Classical Album . CD1. Relax At Home"
The latter portion of the preceding album name i.e. "CD1. Relax At Home", is derived from %_directory%.
Now, I need to format this particular album field with the Mp3 tagging tools at hand, so that that the second DOT in the album field-- the one which follows directly after the CD-number, is preceded with a space. It should then look like this:
"The Ultimate Classical Album . CD1 . Relax At Home"
Could you please assist me with a regular expression, or another scripting function that will take care of this?
Your assistance is always greatly appreciated.
#2
Breaking it down into captures.
To match The Ultimate Classical Album . CD1. Relax At Home
(?i)^(.+?[^\s])\s*\.\s*cd(\d+)\s*\.\s*(.+)
Then $1 will represent the first part
CD$2 the CD with no.
$3 the final part.
You can keep the same reg exp. Just fill in the format with section with whatever you want with either using the $1 $2 or $3.
EDIT I went a little overboard. :w00t:
Your task can use the same expression.
Then use:
$1 . CD$2 . $3
In the replace with in the reg exp action.
Like I said it's overboard but you might learn something from this. But it will ensure that you've got the correct format in all your cases :slight_smile:
#3
Why don't you
replace all dots with blank-dot-blank in a first plain replace action and then
replace all double-blanks with a single blank in the next plain replace action. Done.
#4
Thank you to you both, stevehero and ohrenkino, for your quick responses.
Before I submitted my original post, I was already employing exactly the method proposed here by ohrenkino, but I thought there was an even quicker method. :stuck_out_tongue:
Stevehero, I am going to experiment with your proposal as well. When you went "overboard" :smiley: in the beginning, it scared the wits out of me, but your final final expression may just save me step or two.
Thanks again!
