RegExp to extract text before first comma
I use MP3TAG to set the metadata and file name for my audiobooks. For the file name, I like as much info about the book without making it too long. It is in the format
Author -- Title (Narrator) (Chapter/track).mp3 <- Narrator is stored in %composer%
I had an issue in that some books have multiple narrators (e.g., Frank Mueller, David Cummings, Andrea Martin) and I didn't want the file name to be too long, so I just wanted the first narrator in the list from the metadata. So, I use that TAG -> FILENAME tool and include a REGEXP expression to pull only the first narrator, as follows:
%artist% -- %title% ($regexp(%composer%,^(.+?)\x{002c}(.*),$1)) (Ch%track%)
The REGEXP portion [$regexp(x,e,r,c)] is this
where
$regexp( string function to start regular expression
%composer% x entry, initial string where the narrators are stored
^(.+?)\x{002c}(.*) e entry, the regular expression
^ start at beginning of string
(.+?) extract any character non-greedy → this goes into $1
\{002c} up to first comma (comma must be escaped or Unicode) -> not stored
(.*) extract everything else → this goes into $2
$1 r entry, The field to be displayed
Hope this helps others.
This is not quite true if you use
$regexp(%composer%,'^(.+?),.*',$1)
instead
The potential section following the comma does not necessarily need the parenthesis if you do not want to use it anyway, so $2 is not mandatory.
... but there are so many ways to solve the problem.
incredibly helpful, thank you. it worked for me with songs that have multiple artists, which would mess up the filing convention I use (artist, album, songs)
