For testing the new websource script options setting feature i wanted to define a filter for the format of an album:
"type": "string",
"key": "FilterFormat",
"title": "Media Format",
"description": "Filter used for Media Format.",
"choices": [
"Any",
"Cassette",
"CD",
"DVD",
"File",
"Vinyl"
"default": "Any"
If I use in ParserScriptIndex
json_select_array "format" -1 ", "
ifvar "FilterFormat" "Any"
regexpreplace ".*" "OK"
endif
then in debug.out I get a double OK
Script-Line : 24
Command : ifvar
Parameter 1 : >FilterFormat<
Parameter 2 : >Any<
Output : ><
Line and position:
CD, Album, Reissue, Repress
Script-Line : 25
Command : regexpreplace
Parameter 1 : >.*<
Parameter 2 : >OK<
Output : ><
Line and position:
OKOK
Same thing happens with the regular expression '.*$', whereas '^.*' and '.+' give a single OK,
Is this a bug or a feature of regular expressions?
