I have approximately 15,000 MP3 files with a BPM detail that, for example, has a value of 70.250000 or 70 or 138.540000.
I want to change this to 70,2 or 138,5 or 70,0.
Who can help me?
Try Convert>Tag-Tag or and action of the type "Format value" for BPM
Format string: $regexp(%bpm%,(\d+\.\d).*,$1)
Just a remark: as it is "beats per minute" you have to have a track of 5 minutes length to be 1 beat off. I doubt that anybody will notice.
Decimal values in BPM show IMHO that a human has set the beat - and that human beat is a bit irregular.
Or it shows that a track has different speeds. And then the average beats do not describe the characteristics of such a piece.
can you give me a format string that i just get3 digits, no points of decimal?
Try
Format string: $num(%bpm%,1)
Perfect, thanks for the support
