Lets assume that I have a comment field with content on multiple lines.
And I would like to remove the multiple ----
Rather then counting the number of -- I would like to remove ALL ---- if there's more then one
Furthermore I would like to be able to adapt the - sign to another character.
already thank you for reading this.
Guy
Ambiance description : roots, malta, portuguese, boats -------------------------------------------
All rights reserved
PRODUCER-PUBLISHER
PARSIPARLA
3 rue des Aulnes
03000 AVERMES
FRANCE
tel fax (33) (0) 4 70 20 65 10
info@parsiparla.com
www.parsiparla.com
Guy
All rights reserved
PRODUCER-PUBLISHER
PARSIPARLA
3 rue des Aulnes
03000 AVERMES
FRANCE
info@parsiparla.com
www.parsiparla.com<!--QuoteEnd--></div><!--QuoteEEnd-->
Yopu could appy Convert>Tag-Tag
for comment
with
$regexp(%comment%,-+,-)
This replaces all multi-minusses with one - or whatever you choose as replacement.
However I was not correct in my question.
In fact everything after and including the repeating -- must go and I found that this for mood and genre does work.
If you want to delete everything after the --
try:
Search string: --.*$
Leave replace string empty.
Works as "Replace with regular expression" or as $regexp() in format value actions or in Tag-Tag-conversion.
