If you have tags (fields) with those structures and want the values to be equal to the filename, then you don't need to use a regular expression. You can just set the tag to the filename using a format value action.
An expression is tailor-made to fit one particular pattern. So it would be much easier to point you into a direction if you could supply examples as close to reality as possible.
E.g. if you have a TITLE that looks like this:
344 Filename
you could apply an action to remove the 344 with a replace action.
If you have a TITLE that looks like this
01 - Filename
you can perform an action of the type "Guess values" and the pattern
%track% - %title%.
But this is just guesswork. Please be more specific.
