Hi - I've need to do a very simple Find & Replace using regex.
I just want to strip the numbers and whitespace out:
01 Hello
02 Why
03 Can't
04 I
05 Work
06 This
07 Out?
What do I need to type into the find box?
Also, please can you account for the hundreds of backslashes, dots, stars and brackets that I'm sure will be needed...
I know it's really not that difficult, so I reckon if I see one simple query explained, I'll be well on my way!
Thanks, Richard
PS: If anyone is having trouble with slightly more advanced regexes, this site looks to be very useful:
Regex info
dano
November 1, 2009, 9:12am
2
^\d+\s+
^ match at the beginning
\d+ one or more digit
\s+ one or more space/tab
Hi Dano - Sorry for not replying. I thought I had set up an email reminder for this post, and a flaky IDE cable stopped me worrying about my how my MP3s were tagged!
Anyway, I'm gonna give this a go tomorrow, cheers.
R
That didn't work...
Do I just paste ^\d+\s+ into the 'Original' box, and leave the 'Replace with' box blank?
A normal (non-regex or wildcard) find and replace works, so I know I'm doing it in the right field.
Thanks,
Richard
dano
December 2, 2009, 8:20pm
5
It seems you have chosen the wrong action type, it must be Replace with regular expression
Doh!
Thank you - that explains a lot! (One thing it explains is why I didn't think I understood regular expressions at all. It didn't matter what I did, even the simplest regex would fail!)
Cheers,
Richard
Cool - that worked 99%.
The full expression didn't work: ^\d+\s+
But this did: \d+\s+
(But I guess I can't use that for a song with digits in the title.)
And then as a test, this worked to remove the first space from a field: ^\s
Any thoughts?
R.
But your post here has the answer!
Over and out....
