raynor
September 28, 2015, 10:53am
1
Hello all,
How do I remove all characters in a string (filename) until a substring is matched.
Let's say:
Filename = "abc123 MP3Tag Filename"
Filename = "abcdef123 MP3Tag Filename"
Filename = "abcdefxxx123 MP3Tag Filename"
substring = "123"
Filename will become "MP3Tag Filename"
Thanks for your help.
Create an action of the type "Guess values" for _FILENAME
Guessing pattern: %dummy%123 %_filename%
Or use the Convert>Filename-Filename function:
Source: %1123 %2
Target: %2
DetlevD
September 28, 2015, 3:52pm
3
Additional to the working proposals from user 'ohrenkino' in post #2 .
Remove all characters from the left side of the filename string ...
until and including the last character of the search substring.
' abcdefxxx123 MP3Tag Filename '
' abcdef123 MP3Tag Filename '
' abc123 MP3Tag Filename '
To:
' MP3Tag Filename '
Action "Format value"
Field ......: _FILENAME
Formatstring: $cutLeft ( %_filename% , $add ( $sub ( $len ( ' 123 ' ) , 1 ) , $strstr ( %_filename% , ' 123 ' ) ) )
... or ...
Formatstring: $cutLeft ( %_filename% , $add ( -1 , $len ( ' 123 ' ) , $strstr ( %_filename% , ' 123 ' ) ) )
... or ...
Formatstring: $mid ( %_filename% , $add ( $strrchr ( %_filename% , ' 123 ' ) , $len ( ' 123 ' ) ) , $len ( %_filename% ) )
... or ...
Formatstring: $reverse ( $left ( $reverse ( %_filename% ) , $sub ( $strstr ( $reverse ( %_filename% ) , $reverse ( ' 123 ' ) ) , 1 ) ) )
... or ...
Formatstring: $regexp ( %_filename% , ' ^.*123 (.*)$ ' , ' $1 ' )
... or ...
Formatstring: $regexp ( %_filename% , ' ^.*123 ' , )
DD.20150928.1952.CEST, DD.20150929.0710.CEST
raynor
September 28, 2015, 10:52pm
4
I've tried with Convert>Filename-Filename function, it works well.
raynor
September 28, 2015, 10:59pm
5
DetlevD:
To:
' MP3Tag Filename '
... or ...
... or ...
... or ...
... or ...
I've used $cutLeft(%_filename%,$add($sub($len('123 '),1),$strstr(%_filename%,'123 ')))
It works wonder for me.
Thank you VERY VERY MUCH for your quick help.
Cheers
