Please tell me what action is required to remove the "comma" form the artist field, when the "comma" is the last character of the field.
Example: Donna Summer,
to
Donna Summer
Thanks!
to
Donna Summer
Thanks!
Create an action of the type "Replace with regular expression" for ARTIST
Search string: ,$
Replace string:
(leave empty)
Not working....
It should - at least it works on my machine with your specification.
So check the search string - no blanks in front of the comma.
And check if the comma is really the last character and not an (invisible) blank ...
Or expand the search string to:
Yes !!!! Thank's a lot !! ![]()
If there is also one or more space character at the right side of the given string, then apply this ...
Action: "Format value" Feld: ARTIST Formatstring: $trimRight(%ARTIST%,', ') ... or Formatstring: $trimRight(%ARTIST%,' ,') From: 'Donna Summer, ' To : 'Donna Summer' From: 'Donna Summer , , ,,, ,,,, ,' To : 'Donna Summer'DD.20150730.1027.CEST
