In recent versions, I do not see the "Delete comment" option from tags. How do I set up deleting comments automatically?
I think I read a thread that this function was phased out somewhere around 2005 or something.
Now, you would have to run an action to delete one or more fields.
see
and/or
Not see option in settings.
In previous versions, it was an option, and now it can not be. I have to delete manually. It's time to look for an alternative to mp3tag because the program is already breaking down.
There is none. To remove a field you either blank it in the tag panel, chose <delete> from the dropdown list, press the red X in the extended tags dialogue or use an action of the described kind.
There is no special function to deal with comments.
