Remove cover art using "Actions -> Remove fields" ???
How do I remove cover art using "Actions -> Remove fields" ???
With PICTURE
Hello...
If possible could you write out the format for that action?
Thanks.
ele7en11
Well..
Action #1:
Action type: Remove fields
Fields to remove (semicolon-separated): PICTURE
Thank you...sorry it was so simple.
Recently, I removed covers from a few songs with the Remove Field action set to "cover". It seems to have worked. I gather from this thread that "PICTURE" is the way to do this. How is "cover" different from "PICTURE"?
There is no difference. COVER is an alias for PICTURE.
