Hello --
Is there any sort of batch/scripting operation to delete all the "album art" from each of the
audio files being edited?
Thanks
Hello --
Thanks
I do not know what you mean by "being edited". if you edit a file than you simply right-click on the image in the tag panel.
The action is called "Remove tag field". enter "cover" as field.
Create an Action, or use 'Actions (Quick)' with an action type of 'Remove fields' and use PICTURE for the field.
