I need to remove embedded covers from an Mp3 library, but I then want the leftover space removed from the files.
Can Mp3tag be forced to rewrite files after removing covers? If not, my only alternative is to transcode 30,000 tracks from Flac to Mp3 all over again.
Thanks Dano. You're right, the files are reduced in size. I thought that I'd read that the space wasn't recovered. Should have tested it myself before posting.
2 kB seems like a lot of padding. I don't suppose that's adjustable, is it? I only use Mp3s with my portable players, so I want to minimize their size.
The default padding added by LAME to ID3v2 tags is just 128 bytes.
The thing is... I don't need any padding at all, since the metadata in these files will never be edited. It's all transcoded from the main Flac library.
The allocation unit size of your device is probably significantly larger than 2 kB anyway, so even if it was reduced to 0 is probably would not change the amount of space taken up by the file.
