I listen to a lot of music in other languages and people tend to tag the artists:
"한글 (Korean)"
And I was wondering if there is an action to remove everything except the part that says "Korean" (So I want to remove"한글 (" and ")")
Thank you.
"한글 (Korean)"
Thank you.
Create an action of the type "Replace with regular expression" for the respective field.
Enter as search string:
Replace with
$1
You are a perfect human being. Thank you so much!!!
I hope this will bump.
How would I do the opposite? Keep only what isn't in parenthesis? I want to remove the "(한글)" again:
"Korean (한글)"
Several possibilities:
If the contents in the parenthesis is the last of the string, then everything behind the ( can be removed:
Action of the type "Replace with regular expression" for the field
Search string:_(.*$
(where the _ represents a leading space)
Replace string:
(leave empty)
If you simply want to remove the stuff in the parenthesis but leave everything else (in front or behind it:
Same action
Search string: _(.*)
Replace string:
(leave empty)
Wait I got it. I think. Hold on.
I did. Thanks a bunch again!!!
