Remove everything from first parenthese going forward
how do I create an action that will remove everything from the first parentheses going forward.
ie. track name: Molly (ULTI-reMIX by Mark Roberts). I want to remove "(ULTI-reMIX by Mark Roberts)"
When you stated "track name", I am assuming that you are referring to the placeholder, "%title%". Therefore, use this regular expression format string below:
$regexp(%title%,'^(.+?)\s?\(.+?\)','$1',1)
Try an action of the type "Guess value"
Source: %title%
Target format string: %title% (%dummy%
