This incredibly simple expressions removes extra tracks of the format "/track."
Field: TRACK
Regular expression: /\d+
Replace matches with:
Field: TRACK
This can also do it:
Action type: Replace with regular expression
Field: TRACK
Regular expression: ^(\d+)/\d+$
Replace matches with: $1
Note the '^' and '$' anchor the search string to the beginning and the end.
The '(\d+)' captures whatevers inside.
And Replace matches with: $1 replaces whatever is inside that.
