I have fields that only show under Extended Tag - ican also see them using the softwate Mediainfo. I would like to remove all the tags.
Here the issue, if i select an album using extended tag, it will delete the field, but I wanto delete the field in all folders. Hpw best top go about doing that.
Large database so don't wanto load all at once.
I guess these were fields i create long time ago... lyricist, unsync lyrics... im think best to delete them insyead of odifying.
Any thoughts
