In the Album Field I have
CHBS Vol 05 - Lonesome Blues
I would like to have
Lonesome Blues
I'm sure this has been answered BUT , I'm unable to find it .
Lonesome Blues
With the search words "remove part" I found e.g. this thread:
Do you want to do that for multiple songs?
All of them have some "blabla" before the - (space dash space) and you want only the part after the space dash?
You could try Convert -> Tag->Tag ALT + 5
Explanation:
The tag field ALBUM will be processed with a regular expression.
$regexp(%ALBUM%,(.*) - (.*),$2)
The first (.*) capturing group matches everything before the last - = CHBS Vol 05
The second (.*) capturing group matches everything after the last - = Lonesome Blues
Then your existing content in ALBUM will be replaced with the content of the second group.
As always:
Test it carefully and create backups of your songs before you edit the medata in it.
Thank-you very much for your time and effort , it is appreciated .
