Hi this is my first post on here and let me just say this is the greatest program I have ever discovered, I have already found a few scripts (is that what they're called?) that change all of the ft. to feat. in a click of a button and I LOVE IT. But, for those to work to their fullest I need to be able to remove a bunch of the (Prod by (insert producer here)). I'm sure this is possible, I'm new to this so I would like some help thanks!
If the "prod by" is always separated from the rest of the string by the brackets then you can use an action (=script) of the type "Replace with regular expression for TITLE
Enter as search string: (.*)$
Enter as replace string:
(leave the replace string empty but add a space before the first \ in the search string.)
This removes everything in brackets that is at the end of a string.
If you want to be sure that only the "prod" parts are treated, use
(prod.)$
as search string.
This is case-sensitive, though. So you might have to have a second run with
(Prod.)$
