Hello all,
I've been looking for a resolution to this, but cannot find exactly how to do this.
When I convert from tag to filename, I would like to remove spaces. For example, the artist and song:
The Smashing Pumpkins, Bullet With Butterfly Wings
I would like the filename to be
TheSmashingPumpkins_BulletWithButterflyWings
Thanks in advance!
If you use the Convert>Tag-Filename function, enclose the mask for the filename in a $replace() function, e.g.:
$replace(%artist%_%title%, ,)
Absolutely perfect. Thank you!
