For mp3's with ID3v2 tags (only) saved, when I select all files and select Remove Tag, the tags are not blanking. Even if I save the files after, the tags remain intact. The only way to remove them is to select them all and change each item to and then save the tags.
[Edit] Using the latest development build 2.17i on a Win2k machine.
Just sent a reply.
