Remove Text After Bracket
Hi wonder if anyone can help I’ve looked all over before I post and can’t find exactly what I need, so I gotta lot of music that’s has the record label at the end of a track tag like this for example.
Moloko Bring it back (Davy Remix) smith records
So the record label is always after the closed brackets in this case smith records, I don’t want that information so I need a formula that will delete any text after the closed bracket “)”,
I’ve tried multiple formulas most are deleting the whole text in the field, cheers for any help
Try an action of the type "Replace with regular expression"
Search string: (.*\)).*
Replace string: $1
Yep that will do it!!!!! Thanks for the speedy solution mate and happy holidays!!!
