Hello
I have a Artist tag look like that :
Christina Aguilera - Beautiful
I Want to remove the "String" song name from the Artist tag so it looks like:
Christina Aguilera
What should the Replace with regular expression look like ?
-Rene
Hello
Christina Aguilera
-Rene
Define an action:
Action Type: Guess values
Source Format: %artist%
Guessing pattern: %artist% - %dummy%
Thank you workede like a cham
If i have some numbers look like that in Artist
01 Britney spears - Hit me baby
And will remove track number and title what should the Guess values look like ?
Trying to learn
Sorry bad english
Good day
Actions of the type "Guess values" require a unique character as a seperator between tag-fields.
A white space normally is not such a unique seperator, because a tag-field may have a lot of white spaces.
In this special case with only one white space it will work.
To get the tags TRACK, ARTIST and TITLE out of this artist-tag your pattern has to look like this:
%track% %artist% - %title%
If you don't want to extract one or more of these tags out of the artist-tag you have to replace these tag-variables that you don't want with %dummy%.
If you want to learn how to work with these patterns use the convert-menue "Filename - Tag". There you have a preview and you can experiment.
