Remove variable text from field
Hi, all. I've had a search but I'm not finding exactly what I'm after.
Basically I want to alter the Album field of a bunch of files that will all have variations of a similar pattern that I want to remove
Examples:
In
ANJ019 Matt Hardwick vs Smith and Pledger - Day One
Out
Day One
In
ANJ029 Above & Beyond feat. Zoe Johnston - No One On Earth
Out
No One on Earth
Thanks in advance
Summy
Create an action using Guess values. The source should be the album tag, and the guessing pattern should be something like
%dummy1% - %album%
You can then add a second action step to clear the dummy1 field
