Dont know if i should make a new topic or not but:
Instead of replacing all vowels of a kind in case the string is to long, i would like to replace every vowel after position 5 then 4 ... to reduce the string length.
After spending the day with regex tutorials: i just dont get it. or the tutorials suck. or both.
So from what i gathered this:
should put the first 4 letters as string1 and then all following nonvowel letters as string2 and enter them into the field.
but it does nothing.
What am i doing wrong?
