Removing a particular ID3 tag
I can't find such an option and I need to use ID3Kill to remove ID3v1 tags from my mp3 files. Am I missing something?
Just enable removing of ID3v1 Tags at Options > Tags > Mpeg (and only that) and use :mt_delete: File > Remove Tags to remove them from your files.
Works like a charm. Thank you! :slight_smile:
