One thing that has now occurred to me is that I am manually typing everything and wondered if anyone could help?
Basically, the Filename, Title and Artist are all the same name as formatted as such:
ARTIST / TITLE
For example, a song by Queen called We Are The Champions would be:
Queen / We Are The Champions
What I am doing is manually editing the Title, removing everything to the left of the slash and then manually editing the Artist, removing everything to the right of the slash. Then once I have done an album I will then highlight and change the filename using the convert option.
Is there an automated way I can ask MP3Tag do the editing, know the artist is on the left of the slash and the title is on the right?
Thank your for your reply - When you say "Guess Value" (Import tag field) - Where is this option? Sorry, I am looking under Convert --> Tag to Tag... is this the wrong place?
Indeed it is the wrong place.
You have to create an action (either a quick one or one in an action group - see the tool bar for these 2 functions).
See the HowTos if you feel not confident how to create an action:
