Hello,
I have a song: Eric Burdon & The Animals - San Francisco Nights.flac.mp3
I want to remove ".flac" from the title
Resulting in :Eric Burdon & The Animals - San Francisco Nights.mp3
If you can help
thanks
Hello,
If you can help
thanks
Can you be a liitle bit more specific?
How looks the filename?
How looks the title tag field?
What should be changed?
DD.20090626.0925.CEST
Name of action group: format value
Action type: Replace
Field: _FILENAME
Original: .flac
Replace with:
[ ] case-sensitive comparison
replace .flac with nothing
Thanks worked perfect!
