I've been experiencing a weird bug in the latest build "v3.37-x64" were I cannot remove any previous directories in the tag panel by highlighting it and pressing shift+delete. I have tried installing previous build version 3.36.1 and it works as normal. This then breaks again if i reinstall the latest version. Has something changed or is this a bug?
Just a quick note for you as a new user:
If you want to mention someone, you can add an @ symbol in front of their username.
(There's no need to link to the user profile.)
If you get a solution, please mark such an answer by clicking on the tick symbol:
