For some reason loads of names in the artist field have the track number after as well. Like The Cure7, NOFX12 etc. Anyway to get rid of these numbers in one go?
You can use a Replace with regular expressions actions to remove all numbers from a field.
Care to elaborate please? I don't really know what i'm doing ![]()
Can anyone help please? I really don't know what is meant by replace with regular expression. Well I do know but I have no idea what to write in the regular expression box, whatever I write seems to have no effect
thanks.
Try this:
Name of action group: remove numbers
Action type: Replace with regular expression
Field: ARTIST
Regular expression: (.+?)(\d*)
Replace matches with: $1
remove_numbers.zip (188 Bytes)
Yeah that got it ![]()
Nice one, pal. Thanks.
