I like how the "Tag - Filename" option remembers previously used strings. However, there are so many remembered, I cannot quickly choose my most used ones. I was looking for a way to either clear it or edit it so I can make it a list of my most commonly used strings.
I asked this question recently, and got the same very helpful answer. I have since discovered, though, that in some cases, this doesn't seem to work. The "deleted" string does disappear while the box is open, but then after closing and re-opening it, all the unwanted clutter is back again.
Is there any way to sort the list? As I went through a HUGE library cleanup I created several different strings and found it helpful when I could easily select a string I previously created but they were not in alpha order and as the list grows it is difficult to find the string I need.
