I have this problem with brackets
Some time ago I expanded my actions used for automatic cleaning of errors in tags. Unfortunately, it seems that by taking care of some of my common mistakes are created a problem, discovered later on. And the new issue with my tags is this: I get unnecessary space after the >>)<< sign. So I end up with something like
Symphony #11 In G Minor (The Year 1905) , Opus #103, Movement 1: Adagio (The Palace Square)instead of correct
Symphony #11 In G Minor (The Year 1905), Opus #103, Movement 1: Adagio (The Palace Square)[please note that I do not have issue a pause added at the end of the TITLE / FILENAME]
So I would like to kindly ask for two things:
A] Code for a filter, that would point out all files that have pauses put between >>)<< and a sign, that is not a letter or number. So that I can manually check what other cases they are, because right now I can only think of >>) ,<< and >>) !<< and >>) ?<< but I may be missing some others; so that I can avert a hypothetical another new issue, discovered later on
B] Code for an action, that would remove pauses put between >>)<< and a sign, that is not a letter or number
