Removing Special Characters
I'm trying to setup an action to remove the special character, 0D, from some tags. I know how to create the appropriate action... I cannot figure out how to code the 0D in the Original Field. Can someone tell me what it should be?
Thanks,
David
Do you mean a carriage return ?
The you can use "Replace with regular expression" with \r or \d
