I have searched all through the forums here, and I can't seem to find what I want.
Basically, I have a large number of files all with the first name of the composer at the beginning of the file name, which I don't want them to have. For example:
Gabriel Faure- Sicilienne for Cello and Piano, Op. 78
should be:
Also, I want to remove the ', Op. 78'. Obviously the number is different for each one, and could just be ', Op. 2'.
So,
should be:
Also, how do you check each file name and remove a certain character- in particular ':'?
Through looking at that and this helpful page: https://docs.mp3tag.de/actions
I managed to figure it out. It was
Replace: ^\w*\b
With:
Took a bit of guesswork and extrapolation. Not easy! It should be mentioned somewhere in the same place that any section of a tag or filename can be referred to by the below list, and that these can just be put next to each other with * to say "as many as you want until the next expression".
So ^ is the start of the line, \w* is any sequence of characters until \b which is the end of a word.
Put all that into an action called Replace with regular expression by going Actions: Actions: [New File Icon/Picture]: [New File Icon/Picture]: Replace with regular expression.
Hopefully that helps someone!
Line anchors
^ matches the start of a line
$ matches the end of a line
Sets
[abc] will match either of "a", "b", or "c"
[^abc] will match any character other than "a", "b", or "c"
[a-z] will match any character in the range "a" to "z"
[^A-Z] will match any character other than those in the range "A" to "Z"
\w Any word character - all alphanumeric characters plus the underscore
\s Any whitespace character.
\d Any digit (0-9)
\l Any lower case character
\u Any upper case character
\W non-word character
\S non-whitespace character
\D no digit
\L non-lower case character
\U non-upper case character
\t Tab
\n New line
\r Carriage Return
\r\n Windows style line break
\xnn char with unicode hex value nn
\x{nnnn} char with unicode hex value nnnn
Word boundaries
\b matches a word boundary (the start or end of a word)
\B matches only when not at a word boundary
Because \b points to the end of a word, ...
you have overlooked the fact, that there may be following one or more space characters, between the first word and the second word, ...
therefore your example has left a space character.
