I wish I could code but I can't. When using this script:"%artist% - %title% - %album% - $num(%track%,2)" Is their a way to avoid the - - when there is no album field (or an empty field). And secondly, is there a way to pick the albumartist (with priority to artist) if there is no artist field? Thanks a million.
If you enclose a field variable in square brackets, everything inside the brackets will only be output if the field is filled.
E.g
%artist% - %title%[ - %album%] - $num(%track%,2)
I think that something like this could work:
$if2(%artist%,%albumartist%)
I would fill all the fields, though as non-existing information might lead to strange sorting results.
Thank you so much!!!
