I have thousands of songs that for some reason have tons of leading zeroes like a track number.
For example most of them are in this format in the FILENAME field:
00 - 00 - 00 - 00 - 00 - Someone Like You.mp3
I have already tried this method found in the FAQ but it did not find anything to replace. -
"[i]Remove/trim leading track numbers
Action type: Replace with regular expressions
Regular expression: ^\s*\d+\s*-\s*
Replace matches with:
This regular expression removes the track number from "01 - Anything.." so that only "Anything..." remains.
"^" matches the beginning of the string. Then any numbers of whitespaces "\s*" followed by numbers from 0-9.
The \s*-\s* port removes the hyphen and any white space characters around it. [/i]"
What can I put in the regular expression field that would eliminate these 00's or other such numbers?
