took me a while to figure this out...
To Remove Trailing Characters:
Create a New Action
For action type use Replace with Regular Expression
Choose the field you want trimmed
Enter for Regular Expression: .{4}$
Leave blank the Replace Matches With
In the above instructions 4 characters will be removed from the end of the field. Change the number to suit your needs.
Good Luck!
Roger
