Hi i would like to remove everything from BPM tag except the actual BPM,
How can i do that?
(Always test suggestions not on your original files).
Define an action:
Action type: Guess values
Source format: %bpm%
Guessing pattern: %dummy%[%bpm% %dummy%
It's not working...
It would be easier, if you could publish a text version of the contents of the bpm fields.
Perhaps a pattern like
[%bpm% %dummy%
is working ...
But it should work. At least it works if I test it with your examples from the screenshot.
This one worked out!!!
Thank you guys for the help!!! ![]()
