Removing Unwanted Genre's
I don't know how it happened but I seem to have every Genre known to man in the Genre: drop-down list box. I wish to remove most of them. Problem is when I go to File > Options > Genres there is only 3 Genres in the user-defined-genres list.
I don't know if something is corrupted
See attached screenshot
Any solutions?
Nothing is corrupted.
These are the predefined extended genres of ID3V1:
http://id3.org/id3v2.3.0#Appendix_A_-_Genre_List_from_ID3v1
There is only one way to get rid of these genres:
Enable: Show only user-defined genres
and define genres that you want yourself.
I never tested if these selfdefined genres are the same as the predefined in case they have the same name.
Thanks Much appreciated
