I have batch-searched with foobar 2000 and found lots of the lyrics of my songs and automatically saved them to the mp3 tag.
But lots of them have [Verse] [Refrain] [Chorus] etc. in the lyrics. I don't want that.
Is there an easy way to remove this from the lyrics in one batch with Mp3Tag ? Or do I manually have to alter the lyrics in the mp3 tags ....or just accept that it's there.
As always I recommend to first backup your collection.
You can never know what happens with your collection and your data.
Then I would filter F3 the songs first to list only the songs from your 19000 files where UNSYNCEDLYRICS contains the no more wanted word, with something like: UNSYNCEDLYRICS HAS "[Chorus]"
Apply the Replace-Action to the filtered list of files only.
Do this on some manually selected test files and have a look if you really remove only the parts you don't want anymore.
Yes, you would have to search for the text and the used sign for the "extra empty line" in your lyrics. This could be a carriage return (CR) \r hex 0a or a line feed (LF) \n hex 0d or a combination.
Example Text:
eng||Test
This is the way
This is the way [Refrain]
[Chorus]
oder so
In theory, you could use an Action from type "Replace with regular expression" and use a
Format string like this: (\[[Chorus|Refrain|Verse].+?\])
This would - in theory - remove all occurences of [Chorus...] and [Refrain....] and [Verse...] without looking if there is a space and a colon : or directly a colon : after the search word starting with an opening square bracket. It just removes everything until a closing square bracket.
BUT please be aware:
As you know, in Lyrics there can be whatever text and combination of characters you can imagine. If there is a single open square bracket buzzing around or the closing bracket is missing, the above regular expression doesn't work anymore.
You must carefully check whether the result meets your expectations.
Before you use such a regular expression, please backup your collection.
I can NOT guarantee, if this always will bring the 100% correct result for your lyrics in your files.
Maybe this slightly adapted regular expression could even better match: (\[(Chorus|Refrain|Verse).*?\])
This means:
But again: The content in UNSYNCEDLYRICS is completely unstructured.
There is a high risk that a search term will be overlooked or that too much text will be deleted
