Hello,
I'm a new user of this great software and i searched across this forum to find an answer for my question but i didn't found a specific one.
So, my problem is that i have a lot of mp3 files named ARTIST - SONGTITLE www.examplesite.com
I want to remove all the web addresses including the ones that don't start with a WWW (like ARTIST - SONGTITLE examplesite.org)
Can you help me finding the replacement string to rename the files in order to dissapear the web address?
Thanks a lot!
dano
2
Make a new action
Action type: Replace with regular expressions
Field: _FILENAME
Regular expression: \s(www.)?[A-z0-9]+.(org|net|com)(?=.)
Replace matches with:
[ ] case-sensitive comparison
This is a very simple example.
Could I just add that I have 2 additions to this and would like to know how to remove them?
I tried the expression above and its fine, except it leaves a bit.
eg.
01-artist-song_name-www.mymp3.com
01-artist-song_name - www.mymp3.com
01-artist-song_name [www.mymp3.com]
in all examples above, how can I add to the expression and also remove the "-" and " - " (spaces included) to be removed too and " [www.xxxxx.com]"
thanks for any help!
dano
4
[- _]{1,3}\[?(www\.)?[A-z0-9]+\.(org|net|com)\]?(?=\.)
