I have numerous files in the same album without artists and I want to rename all of the artists at the same time with "Various Artists".
How do I do this?
Thanks
How do I do this?
Thanks
You see the tag panel at the left? If not, press crlt+q
Select all file you want to edit in the file list and write "Various Artists" into the artist field in the tag panel. Then save by clicking on the disk symbol in the menu or press ctrl+s.
Thanks, wasn't aware of the saving part.
