great application! Thank you very much.
I have one suggestion concerning one option I often use, the "Convert -> Tag to file name". I usually use it to archive my music with proper names and in proper folders.
I think it would be great if that option could also copy. That way, you could easily transfer music from a player to your computer. For example with an iPod, you can select the folder where the music is hidden (after having made it visible), browse it with Mp3tag and select what you want and export it to the location of your choice. It would be nice especially for the iPod device as the music is sorted by iTunes which converts all file names into codes and stores them into various folders also with with code names.
Thanks anyway for all the efforts
