Hi guys!!!!!!!!
I want to rename ALBUM TAGS with the info. on ARTIST TAGS...
Is that possible???
Tks
Hi guys!!!!!!!!
Is that possible???
Tks
Try: Actions - Format Value
From help file:
Format valueFormats tag fields by other fields content.
You can use placeholder(s) for any tag field as format string to format the content of the field specified.
Example: to copy the content of the comment field to the encodedby field, set the field to ENCODEDBY and the format string to %comment%.
:Thank you Oblio for your help
It worked just perfect...
Have a nice day....
w00t:
